Read string control on pressing enter
I have a string control and a boolean button. The button is the input of a case structure. If TRUE I read the string control and send it through serial.
I want to set the button TRUE when I press ENTER (on the keyboard) after I finished typing into the string control.
I want to mention that I already set the "End text entry with Enter key" in Tools>Options>Environment.
Dragos
(5,564 Views)
A much simpler way to do this is to forget about the button and use LabVIEW's Event Structure.  When you press Enter while entering text into a String Control, you change the value that the Control represents.  The Event Structure lets you execute code when a Control's Value changes, just what you are describing.  If you don't know about them, there are a number of tutorials and White Papers on them including this [link removed; article no longer available],
Bob Schor
(5,561 Views)
I know that´s an old thread. But I´m sure there are lots of people with the same question.
There are two solutions:
1. Right click on the button --> Properties --> Key Navigation --> Set "Toggle" to "Return" --> OK
2. Do the same thing programmatically (necessary if you want to assign the Return key to another button while the program is running. In this case you can simply use a property node like in the attached example vi.
Regards
(4,965 Views)
test
(4,925 Views)
