All you have to do is instead of using the cell range (A3), just use the cell name into the into the Cell range node.
The attached image show a bit of code when I had to this to write to a named cell. This code had to create all the references first, so if you already have a reference to your sheet open, you'd probably just need the '_Worksheet>Range" node with the name specified.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
