Reading 0x00 in binary file as space 0x20
Here is a zip folder with the binary file. Thanks for the help.
Message 11 of 20
(4,129 Views)
Accepted by Nick_A1
OK, this file does have nulls and LabVIEW has no problems reading it. There is no problem.
Message Edited by altenbach on 11-13-2008 04:48 PM
Message 12 of 20
(4,108 Views)
OK, I think it's working. Thanks a lot for your help. Was it behaving differently because I was using build array instead of just dumping the data directly to an array? Or because my count was different?
Message 13 of 20
(4,088 Views)
No, the "built array" or "count" do not change the data. Most likely you had two files with similar names and mixed them up. 😄
Message 14 of 20
(4,082 Views)
I am having similar problem. When reading binary stream the 0x00 is interpreted as 0x20 (space)? Any ideas?
Message 15 of 20
(3,892 Views)
Are you sure you have nulls? As the discussion indicated, the user had a file that actually had spaces, not nulls, so LabVIEW was working correctly. Do you have a file that you can upload?
Message 16 of 20
(3,876 Views)
What is happening is I think is matter of representation of binary characters into a text editor. After conversion to ASCII I think it is OK.
Thank you for your help anyway!
Salud!
Message 17 of 20
(3,857 Views)
Why are you converting to ASCII? There should be no need for that. If you want to open the file then I suggest using a Hex Editor or Notepad++. Notepad++ has a Hex Editor plug-in.
Message 18 of 20
(3,847 Views)
I am receiving the stream of binary data from my remote instrument and I have to convert to ASCII in order to visualise them...work with the data....
Message 19 of 20
(3,838 Views)
TinoMK wrote:
... and I have to convert to ASCII in order to visualise them...work with the data....
This does not make sense.
  • To visualize binary data, simply set the string indicator to hex display.
  • Working with binary data is also much easier and efficient.
Message 20 of 20
(3,821 Views)
