Reading 115vac 400Hz
I am working on reading 115vac 400Hz power supply using an PXI-4472.
I got it working, but if the signal gets lost the loop crashes.
How do I stop it from doing this?
Anyone got an example of reading ac voltage even if its 0volt?
kls
(5,997 Views)
You should attach your VI so people can have a look...
(5,977 Views)
I will do it tomorrow 😏
kls
(5,964 Views)
In adition to the vi, it would be interesting to know how you are reducing the 115 VAC to a level that is compatible with the PXI-4472.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(5,938 Views)
Accepted by Kimlorentz
Got it working.
It was my sampling settings that was wrong and how I put my code together.
For reducing 115vac i used resistors (ATTENUATOR 20:1).
OLD vi. code
New vi. code
kls
(5,911 Views)
EDIT!!
The ATTENUATOR is an 40:1 and not an 20:1.
kls
(5,864 Views)
