Reading OBDII data without Automotive Diagnostics Command Set
Hello All,
Just wondering whether anyone has had any succes with reading OBDII data from a without using the Automotive Diagnostics Command Set add in for LabVIEW.
I mean, just using the standard CAN or XNET vi's?
I would like to read engine RPM and vehicle speed etc.
I have been able to read these PID's by downloading an evaluation version of the add-in, but I am slightly reserved to spending £900 for the software if it can be done otherwise.
Rhys.
(5,841 Views)
The OBDII port is essentially just a CAN connector - you should be able to read the CAN messages from the port using either NI's CAN hardware or another CAN device (e.g. Kvaser/PCAN). That's the easy part.
The hard part is decoding the messages - you can use XNET to do this (XNET Conversion VIs) but you need to either create your own database of the messages/signals or use an existing one. You can either do this using the XNET software to build the database yourself or use a CANdb (.dbc) file or any of the other sort of database file that XNET supports for the CAN signal definitions.
I can't say I've ever tried it in my own car, but we do a lot of stuff with CAN and use both NI and non-NI hardware to do this and then use XNET to parse the messages into signal data.
(blog)
(5,833 Views)
DIDs and PIDs aren't signals, and the XNet conversion library will be little help for reading this information since you generally need to issue a request before a response is sent.  Then theres other issues with multi-frame messages that XNet doesn't support.  It can be done but is a manual process of getting raw frames and doing the conversion.  That's why these toolkits were made.
By the way you'll probably find more help on the automotive subforum.
http://forums.ni.com/t5/Automotive-and-Embedded-Networks/bd-p/30
You'll probably need to look into the ISO spec on how to read DIDs and PIDs.  I might be wrong but I think it is ISO 15765 or something.
(5,817 Views)
Thanks for your initial replies.
I have connected a CDAQ with a 9862 CAN module to the OBD connector of the car.
I am able to read some data using the Bus Monitor. But the data that I require (engine rpm) is not visible.
As you mentioned, I believe that a request has to be sent for other information, and constructing that data frame for the request is the difficult part (unless I'm using the ADCS of course)
Rhys
(5,812 Views)
