Reading Pulsewidth Through Serial
I am using a Parallax accelerometer to measure acceleration and the output of the accelerometer is a TTL Pulsewidth.
I am wondering if it is possible to read the pulsewidth in through Serial DB9 connection and measure the actual pulsewidth.
Thank you for any help.
(2,595 Views)
No.
(2,592 Views)
The short answer has been given. You can't do what you asked directly with a serial port. You need a device between the digital logic (TTL pulses) and the serial port - specifically a Digital Input DAQ. There are scores of these available for under $100. Trouble is, accelerometers are high speed devices, so you'll be limited by what you can detect by the speed of serial port communication, and DAQ's sample rate. Look for >1000 samples per second, assuming the Parallax can run at 115,200 baud.
Richard
(2,575 Views)
