Reading Text File
I am getting "ERROR 43 Open File+.vi:File DialogLabVIEW: Operation cancelled by user."  The file appears to be in the correct place on the Rio... code works in test locally.
(3,318 Views)
Accepted by tom386
My guess is that you have a default value of an empty path in your control.  Change it to a constant.
(3,286 Views)
Thank you... that worked.
(3,251 Views)
