Reading Text File
I am getting "ERROR 43 Open File+.vi:File DialogLabVIEW: Operation cancelled by user."  The file appears to be in the correct place on the Rio... code works in test locally.
(3,329 Views)
Accepted by topic author tom386
My guess is that you have a default value of an empty path in your control.  Change it to a constant.
(3,297 Views)
Thank you... that worked.
(3,262 Views)
