Reading a .tlk file
We have a rather rickety piece of software (non-labview) that stores large table data in .tlk files.  To try and negate the effect of not being able to access the data when this software doesn't work, I want to be able to read the contents of the .tlk files and export their contents to Excel.  I am familiar with writing data to excel, but I am unsure how to go about reading the .tlk file.  Is this actually possible with LabVIEW, or am I in danger of careering down the wrong path?
I ask this because it's a few days until I can get back to the office, but my boss wants to know if I can do it.
Never say "Oops." Always say "Ah, interesting!"
(3,916 Views)
Do you have a sample, or at least a description?  The only thing I found about .tlk files on the interwebs was stuff like "Language dialog file used by BioWare first-person shooter games."
Jim
(3,900 Views)
I have been monitoring this forum post to possibly offer support when you return to the office. I see you have not replied in a while and am just enquiring if you are still working on the issue?
Kind Regards,
Jamie Jones
(3,844 Views)
Thank you both for your replies.
This little project had temporarily been put on hold as other things needed doing with a higher priority.  I am not in direct contact with the 'old' software that stores data in .tlk files and, since the data is sensitive, I am still waiting to be provided with a .tlk file that contains dummy data so that I can get on with trying to read it in LabVIEW.  Until then, I can't really provide any more information on these file types (other than what jcarmody turned up, which is about as much as I know so far too).
Our offices are closed for the Christmas period, so I expect (perhaps hope) to be working on this come January.  If anyone knows whether LabVIEW is capable of reading the files, or has worked with them in the past, I would appreciate any advice you can offer.
In the mean time, Merry Christmas! Smiley Happy
(3,807 Views)
First off, apologies for the thread necromancy (I figure it's somewhat justified in order for me to provide some closure on this matter).
I've finally been provided with a couple of TLK files containing 'dummy' data to work with, and I had a conversation with another guy who's used these files before.  As it turns out, they appear to be a type of archive file.  In this particular case, they contain a group of XML files with all the data I was trying to get hold of.  My initial mistake was to try and treat the TLK as a single file rather than an archive, which produced some confusing results!
It should be relatively plain sailing from here, but a thank you to those of you who were prepared to try and lend a hand. Smiley Happy
(3,744 Views)
