Scan Mode for C-Rio 9074
So I'm using the C-Rio for my research, and I'm trying to program the C-Rio 9074 in scan mode, however, then programming options are not popping up whenever I select the C-Rio from New-> Target and Devices.
(3,248 Views)
Some things to check:
1.) Did you install the latest NI-RIO, Real-Time, and FPGA Module?
2.) Did you cofigure your LAN settings properly on your computer?
3.) How are you connected to the cRIO - through a switch or directly from your computer to the cRIO? If you connect directly to the cRIO, are you using a crossover cable?
4.) Do you have your firewall and anti-virus turned off?
(3,242 Views)
Okay, I installed the Real Time module, FPGA module, upgraded labview from 2011 to 2012, and installed the C-rio drivers. However, I still cannot get into scan mode. I included a picture of the error
I thought I configured my network correctly. I step my local area connection 2 with an ip address of 10.0.0.1 and a subnet mask of 255.255.0.0.
Finally, I set the C-rio Ip address to 10.0.0.2 and subnet mask of 255.255.0.0
(3,223 Views)
Hi, here you will find a general troubleshooting guide. Also, if the hardware is visible in MAX make sure the cRIO controller is matching the version of the drivers currently installed on your developer computer.
Alejandro C. | National Instruments
(3,204 Views)
