Reading data from URG-04LX-UG01
Hi.
I'm curently trying to create a vi that reads the data from a URG-04LX LIDAR laser. When I try to connect to the device through LabVIEW I can't read anything from it, if I use the Basic serial write and read example vi all I get is nothing or if I have the write function on I get the write section in the read section.
I'm using LabVIEW 2012 for Mac, have anyone tried to do this before or know how to fix this? I can find the device in the VISA configuration program and in the dropdown menu in the vi but as I said can't read from it.
(2,660 Views)
Hi Anton,
Have you seen this page:
https://decibel.ni.com/content/docs/DOC-32172
It presents a specific example of how you can interface with your laser. It should give you some pointers/ideas on how to implement the VISA programming.
(2,593 Views)
Thanks. Yeah I've seen it, we got it to work now! thank you for the help!
(2,591 Views)
