arduino labview
bonjour ,
s'il vous plait comment je peux adapter les sorties de chaque machine( ( 6 sorties  ) ( sachant que je travail sur toute une ligne de production composé de 11 machines )  ) par une carte arduino  a travers laquelle je vais faire une interface d'analyse des données avec labview
Message 1 of 8
(3,579 Views)
@henifadwa wrote:
bonjour ,
Google Translate
hello,
please how I can customize the output of each machine ((6 outputs) (knowing that I work on a whole production line consists of 11 machines)) by an Arduino board through which I will make an interface of data analysis with labview
This forum is for English speaking only.  Please post in English, or post in the French section of the forums.
Google Translate
Ce forum est pour anglophones seulement. S'il vous plaît envoyer en anglais, ou les poster dans la section française des forums.
Message 2 of 8
(3,555 Views)
hello,
Message 3 of 8
(3,546 Views)
@henifadwa wrote:
hello,
You are using terms without explaining what you mean.  Each machine?  Do you mean you have 11 computers and you want 6 of them to have different applications on them?  Do you mean you have 11 Arduinos and you want 6 of them to have different code?  Do you realize that the LIFA toolkit doesn't convert LabVIEW code to arduino, it simply is a way to read and write the arduino I/O by commanding it over serial.
Post more clearly what you want.  And if possible post some code showing what you have done to try to achieve those goals.
Message 4 of 8
(3,543 Views)
i have 11 machines wchich product PCB , they are linked by  an industriel protocol called SMEMA .
the outputs are from sensor ( 0to 24 V )
so , i want to analyse those outputs of machine with labview
Message 5 of 8
(3,534 Views)
Can I assume you want to use the Arduino hardware to take the 0 to 24V signal?  If so then you'll need some kind of voltage dividor, or signal conditioning setup because the Arduino only had a 0-5V analog input.  Then using the LIFA toolkit you can quite easily read what the voltage on the various I/O pins are and perform analysis with them.  I'd recommend downloading the toolkit, downloading the LIFA firmware to an Arduino, then test out the read AI function.  Post the code you have here if you get stuck.
Message 6 of 8
(3,508 Views)
OK 🙂 thank you :)))
Message 7 of 8
(3,471 Views)
@henifadwa wrote:
OK 🙂 thank you :)))
The best kind of thank yous are kudos, and accepting replies as the solution.
Message 8 of 8
(3,452 Views)
