Reading from a USB port
           Iam attaching a simple example to read datas using a USB port.But I don't have any DAQ card.And I tried to simulate a DAQ assistant but while running there, shows some errors.Can anyone have any suggestions for this problem???PLZ help
Thanks as kudos only:)
Message 1 of 13
(3,750 Views)
hi danill33
without any DAQ card how you can access the Daq Assistant..
you should be having daq card with Usb connection or with PCi card or PXI card
without you can not access the daq assistant. but if you wan to transfer your data then you can use UDP data transfer examples...
hope u understand
tc
Message 2 of 13
(3,746 Views)
Hi Nabel,
              Using the Measurement&A utomation Can we simulate a DAQ device without DAQ card??
Message 3 of 13
(3,733 Views)
Yes, you can simulate certain devices through MAX. However, there are some decives which cannot be simulated through MAX.
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 4 of 13
(3,715 Views)
hi danil
you can access Max without DAQ card but you can acquire data without any hardware connected
Max just show you the which hardware or card like PCI/PXI chasisss or card is conneced
hopes you undestand
Message 5 of 13
(3,707 Views)
@Nabeloabbasi wrote:
hi danil
hopes you undestand
No, you can acquire simulated data when you select to simulate a DAQ card in MAX.
Danil,
You need to provide the type of DAQ card you are using. Your VI shows a VISA Write and Read. These functions are not used for DAQ devices and you cannot simulate them and you cannot use the DAQ Assistant for non-DAQ devices.
Message 6 of 13
(3,705 Views)
yes ur right.. denis
Message 7 of 13
(3,698 Views)
Thanks to all for valuable suggestions.Yes I used VISA read and write functions.So in this case how to simulate to view a proper output??
Message 8 of 13
(3,678 Views)
Hi Fragger
               I have one more doubt.In my attached example there shows a dropdown list for VISA resourse name.Can it be a USB port??Using an usb CABLE can we read data
using that attached example??Or that example is capable of  serial port reading only??
plz reply
Message 9 of 13
(3,675 Views)
No. You cannot simulate a VISA device. You need something connected at the other end of a USB cable.
Message 10 of 13
(3,672 Views)
