Reading images efficiently
Something like this should do :
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 11 of 25
(2,209 Views)
I'll try this
Message 12 of 25
(2,208 Views)
What is the name of the function placed under 'index array' function? I cannot find it.
Message 13 of 25
(2,201 Views)
Accepted by bikekowal
"delete from array", indeed it's icon changes slightly depending on what in conneted in.
but the png I posted is a snippet, it means it contains the code, download the png to your desktop and then drag and drop the file on an empty block diagram, it will import the code, magic!
Epictetus
Antoine Chalons
Message 14 of 25
(2,198 Views)
This 'snippet' is amazing. I haven't seen that before, it is really great tool.
I run the code and unfortunately got a following error:
Error 16 occurred at Read BMP Header Info.vi
LabVIEW:  Image not found.
NI-488:  SRQ stuck in ON position.
Message 15 of 25
(2,196 Views)
I restart the computer and now its working. And as I see, the application is working quite fast. Thank you very much for your help 🙂
Message 16 of 25
(2,189 Views)
Maybe you help me with another thing - is it possible to delete a file after reading it? I mean delete an image from disk after displaying it?
Message 17 of 25
(2,184 Views)
sure, in the "file" >> "advanced" palette, there is a "delete" primitive.
Epictetus
Antoine Chalons
Message 18 of 25
(2,180 Views)
OK, thanks, but I rather mean deleting the file automatically - I get one image, display, delete then get another one, display, delete and so on... Till tomorrow I won't have a chance to check it so will this be ok?
Message 19 of 25
(2,174 Views)
Epictetus
Antoine Chalons
Message 20 of 25
(2,169 Views)
