Reading nvarchar from MS-SQL?
I need to read some data from an MS-SQL database with labview by running the pre-written stored procedures provided by our customer. The code I have is:
Which runs fine but the second column of the returned string is giberish:
I have really very-very little idea how to use a Labview with a database, but after googling a while it seems that the issue is caused by that the 2nd column is an "nvarchar". Also by googling I tried have copied the query of the stored procedure to labview (so instead of calling the stored procedure, I called the query directly) and changed the query from this:
SELECT BR.ID, BR.ModuleID, BR.IS, BR.WR FROM Results
to this
SELECT BR.ID, CAST (BR.ModuleID AS VARCHAR), BR.IS, BR.WR FROM Results
With my code runs just fine and the second column is prefectly fine. As I said, I have no expereinces with DBs, but is there a way to do this CAST on the returning values coming from the stored procedure?
(I also found some tips of doing a unicode conversion which I tried, with partial success because it seems that only part of the real value is returned on that way. So if I convert the giberish looking chrs to unicode then I only get the first part of the string, not everything)
(3,065 Views)
Hi 1984,
How do the strings look like in hex display mode?
(3,043 Views)
Normal view:
Hex view:
Casted to varchar:
(EDIT: and for now I can't even reproduce that parital unicode conversion.)
(3,039 Views)
to this
Any chance to get the possibility to change the stored procedure itself ?
(3,022 Views)
Working on that but its very unlikely as the DB is maintained by a 3rd party company. (who probably doesnt care too much about this (seemingly) labview related problem)
(3,015 Views)
I don't think, that this is a LABVIEW problem. It could be lousy, when it comes to character sets.
MYSQL unterstands the keyword nvarchar but it will be translated to varchar with UTF-8. Also important could be the global character set and/or the character sets of the session, schema, table, column. So we need much more information. Are you able to export the schema or parts of the table including the create statements?
(2,980 Views)
I'm unsure if this is related but the collation of the db is Latin1_General_CI_AS. As I heard this in not unicode and as I heard this determines if by default the nvarchar stores values in unicode or if it doesnt. I also heard that its possible that whoever filled the db with values used a software which sent the values as unicode to the db and as nvarchar can store unicode it was stored like that despite the collation.
As you might noticed that all of these are wild guesses although the guy told me this is normally a pretty convincing one.
(2,960 Views)
