Reading of a password protected excel file
Hello...
I want to export data from a password protected excel file...how it's possible?..need to use ActiveX functions? please help me
(5,229 Views)
Accepted by valiyattil.26
I'm afraid that Report Generation Toolkit does not support password protected Excel files.
But you can easily use ActiveX.
Attached you will find an example of such code.
(5,157 Views)
Thank you sir......thank you very much....it's working....thanks alot...
(5,151 Views)
Sir,
Once again thank you for your code...I also want to know the same using rgt.. with rgt it's possible to write to a password protected excel file...but reading not working...sir,  I think with rgt coding will be easy.. please help me in this regard
(5,056 Views)
I was wrong in my previous statement.
RGT can open password protected Excel file but only after small modifications.
Please check solution under:
https://forums.ni.com/t5/Example-Program-Drafts/Using-password-protected-Excel-templates-for-Report-...
(5,044 Views)
Thank you sir...
(5,040 Views)
