Real-Time analog input for fluid level
I want to write a VI for 1. sbRIO 9641 with Real-Time target 2. Indicator is analog 4. With a volume range 5. Give read out to gauge on front panel 6. Indicator light for low level on front panel 7. Sub VI with sound from Examples(Sound Player.VI) goes off same time as indicator low level light 8. Fluid is normally static but may evaporate/burn off or maybe occasionally discharged then refilled 9. Tied into Real-Time AIXX Help! Examples posted appreciated
(3,281 Views)
Hey Russ,
To get you started, I'd recommend you use the Real-Time Project Wizard which will set you up with the basic architecture you'll need. Instructions for using the wizard can be found here:
Creating a LabVIEW Project with the Real-Time Project Wizard (Real-Time Module)
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/creating-a-labview-project-with-t...
I'd also reccommend you look through the getting started manual found here:
Getting Started witht the LabVIEW Real-Time Module
https://www.ni.com/docs/en-US/bundle/371375f/resource/371375f.pdf
Hope this helps!
--Ryan S.
(3,249 Views)
OK, helpful and I am guessing that one must go through Getting Started witht the LabVIEW Real-Time Module and the wizard to harness the power of Real-Time? Also, just a wild guess that one must have the sb-RIO device to debug and to
"Run as startup" per the "Getting Started"?
So now onto the original request.
(3,238 Views)
