Real-Time and remote web user interface?
Goal: To have an executable running on my Real-Time controller, and have someone log onto a web page and monitor/control the application.
I have used the web publishing tool while developing on a host computer to monitor a vi, however, for deployment, does the Real-Time controller have its own web server to provide such a service?
- Con
(3,419 Views)
Yes the realtime unit will allow you to monitor over the web using either remote front panels, ftp, tcp/ip, etc. You will first target the rt app and then you will need to enable the web server. You must keep in mind though that you want to isolate your data transfer or gui updates. Because these items are non deterministic. If you place them into your deterministic loop it becomes non deterministic. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,405 Views)
BJD described what you've to do. If you need step by step instructions, then this Knowledgebase could be useful
Luca
(3,389 Views)
Thanks for the helpful information!!
(3,373 Views)
