Real time OS
I would like to use a desktop PC as an RT target.
I used MAX and real time 2015 module to do so.
Due to the following link the RT OS is Pharlab:
http://digital.ni.com/public.nsf/allkb/35F1FD98520D6E0E8625783A005AF557
Is there a way that to have Linux RT instead of Pharlab?
Also I run OSversion.vi mentioned in the above link on RT target and get Pharlab 13.1 as RT OS.
I expect NI ETS 2015.
Why the RT OS of real time module 8.6 is installed instead of 2015?
Thanks in advance.
(3,184 Views)
It's pharlap, not pharlab. You misspelled it the same way in your other thread as a different user and where you got an answer.
http://forums.ni.com/t5/LabVIEW/Installing-Multi-port-serial-card-on-RT-target/m-p/3223594/highlight...
(3,171 Views)
