04-05-2021 10:49 PM
Hi everyone!
I developed a PID control using labview and it's working fine!
Now I need to get some values like the settling time of the control but I don't know how to do it properly and accurately!
I will adjust the VI I've developed.
I am plotting the two signal ( set point and the signal I want to control).
Does somebody know how I can get this time?
Thank you very much!
04-06-2021 11:16 AM
Hi navarro,
can you provide example data?
Or atleast an image showing those plots so we can provide comments?
Do you know the signal/control theory to know how to determine settling times?
Can't you use that knowledge on your measurement data?
04-06-2021 04:25 PM
Thanks for answering me!
Here you can see the graph I am getting.
The thing is , I need to get the time it takes to become stable. I don't trust the time of this graph. I think the other modules are takin too much resource.
04-07-2021 11:50 AM - edited 04-07-2021 11:53 AM
Hi navarro,
When you don't trust your own VI then you should improve it!
I would start with replacing all those ExpressVIs (mostly DAQAssistents) by plain DAQmx functions! This will greatly improve the performance of the VI.
Then you should switch over to hardware-timed DAQmx tasks to improve timing even more: no need to run a loop with a 10ms timer when your hardware can ensure a 100Hz samplerate much more precisely!
Btw. you also need to define "become stable": there is some fluctuation in your plot all the time…
