Real time PID
Hi everyone!
I developed a PID control using labview and it's working fine!
Now I need to get some values like the settling time of the control but I don't know how to do it properly and accurately!
I will adjust the VI I've developed.
I am plotting the two signal ( set point and the signal I want to control).
Does somebody know how I can get this time?
Thank you very much!
(1,818 Views)
Hi navarro,
can you provide example data?
Or atleast an image showing those plots so we can provide comments?
Do you know the signal/control theory to know how to determine settling times?
Can't you use that knowledge on your measurement data?
(1,757 Views)
Thanks for answering me!
Here you can see the graph I am getting.
The thing is , I need to get the time it takes to become stable. I don't trust the time of this graph. I think the other modules are takin too much resource.
(1,745 Views)
Hi navarro,
When you don't trust your own VI then you should improve it!
I would start with replacing all those ExpressVIs (mostly DAQAssistents) by plain DAQmx functions! This will greatly improve the performance of the VI.
Then you should switch over to hardware-timed DAQmx tasks to improve timing even more: no need to run a loop with a 10ms timer when your hardware can ensure a 100Hz samplerate much more precisely!
Btw. you also need to define "become stable": there is some fluctuation in your plot all the time…
(1,717 Views)
