Real time data capture using NI5671 and I PXI-7951R
       I am planning to purchase the above mentioned two NI products. However I want to know is it possible to acuire Images Pixel by Pixel in REAL TIME using Labview RT module using the above two devices ???
I am aqcuirig intensity values based on pixels using a XY SCAN.
Please give me your advices.
Thank you.
Best
Abhi
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(2,304 Views)
Hi Abhi,
Could you please elaborate on your intended application?  Did you mean the NI 5761 instead of the NI 5671?  Also, what exactly do you mean by acquiring images pixel by pixel?  Are you using a camera or image files?
Cheers,
Jeff S.
(2,282 Views)
