Startup EXE is not running in cRIO-9002 controller
Hello all,
I have a compactRIO with NI 9002 controller. The controller has following software.
1. Labview real-time 2011
2. NI-RIO 4.0
I have made simple User LED blinking application under RT target using Labview 2011 and build EXE. But, EXE is not running after successful deployment. I have tried troubleshooting the cRIO controller using following NI knowledge base.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8jFSAS&l=en-US
Kindly help me to solve this issue.
Pradeep Kumar Achu
(3,815 Views)
Accepted by topic author Pradeep_Kumar_Achu
You need to disable the SSE2 optimisation option in your build properties as you are running on a cRIO 9002, which is an older model that does not support this feature:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvconcepts/sse2_caution/
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,810 Views)
Hi Thoric,
Thank you very much.... Problem got solved.
Disabling SSE2 Compiler Optimizations
Pradeep Kumar Achu
(3,800 Views)
You're welcome. And please consider marking my reply as the solution, this will encourage other developers who encounter the same problem as you to read this thread Smiley Happy
(3,797 Views)
