Real-time module. Feed a variable's value into a 1D Array
Hi all,
I'm sorry to post such a simple question but I have been really struggling with this for more than 2 days.
I have Real-Time project and two variables:
1) MyVariable.
  - Variable Type: Single Process.
  - Data Type: Double.
  - RT FIFO enabled.
  - FIFO type: Single Element
2) MyArray.
  - Data Type: Array of double.
  - RT FIFO enabled.
  - Number of Elements: 10
I have a VI which is called inside the critical loop. How can I make that in every iteration of the critical loop, the current value of MyVariable is fed into MyArray?
Thanks in advance.
(2,556 Views)
look at the attached image.
I think that it can help you.
Have a Nice Day
ANdrea
(2,535 Views)
