Showing results forĀ
Search instead forĀ
Did you mean:Ā
Receiving 10,000 Bytes ?
Hi, i am new in labview i just want to receive bytes from a device which is sending 10,000 Bytes in a row
(3,574 Views)
Please rephrase as a question.
(3,566 Views)
Accepted by Akbar7110
Open communication with device (Visa?)
Send command
Receive result (all 10000 bytes?)
Possibly repeat Send/Recieve
Close connection.
Save result to file
Profit.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,551 Views)
- Indicate the communication medium  , SerialPort , Ethernet TCP/IP , USB ,
- Indicate the protocol in which the data is packed.
- Is any handschaking required before the data is send
Floris Reinders
Senior Project Engineer / CLA
(3,546 Views)
Set up a webcam
Start acquiring images
Analyse the images to detect puffs of smoke from the fire across the room
Decode back into binary
Don't forget to include a termination character
I'm assuming, due to the lack of further information that your device is communicating via smoke signals.
(3,499 Views)
Of course grey-code encoding should be used, or it will be terribly inefficient.
(3,487 Views)
Which "Native Tribe" decoding algorithm to use ? or just Morse
Floris Reinders
(3,475 Views)
