Recently upgraded from 7.1.1 to LV2009 and noticed LV 2009 is missing \vi.lib\DAQmx\ !!!
I recently upgraded from LV7.1.1 to LV2009 and noticed LV 2009 is missing \vi.lib\DAQmx\. I tried to copy my DAQmx library over from LV7.1.1\vi.lib and did a mass compile of that directory but the compiled files have a bunch of screwed up connector sinks showing as "void".
Anyone have any suggestions how I can acheive a proper DAQmx library within LV2009? Does LV2009 not come with DAQmx support??!!??
(2,618 Views)
Accepted by topic author aaronb
After you install LabVIEW (any version), you need to run the DAQmx installer to install support for it with LabVIEW. Even if you already had DAQmx installed, you still need to re-run the installer to install LabVIEW support.
Jarrod S.
(2,615 Views)
Didn't know that. Thanks Jarrod!
(2,586 Views)
