11-03-2006 09:03 AM
11-06-2006
09:33 AM
- last edited on
08-22-2026
01:42 PM
by
Content Cleaner
Hi Zacseph,
What type of connection do you have to these devices?
I can't seem to find the driver for that device. If you have LabVIEW 8.0 or newer then you can search for the drivers using the menu bar.
Tools>> Instrumentation>>Find Instrument Drivers
If not then go to https://www.ni.com/en/support/downloads/instrument-drivers.html and search from here.
If you can't find a driver then there is an option on the website to request a driver and then the only way forward is to wait (I wouldn't do that) or create the driver yourself using the I/O assistant (if you are using GPIB or SERIAL).
If you would like some more information on this then go to https://www.ni.com/en/support/documentation/supplemental/12/instrument-i-o-assistant-explained.html This will give you a great headstart.
Let me know how it goes.
AdamB
06-26-2008 07:48 AM
11-20-2009 11:16 AM
I am also trying to program for the Valco Mulitport Valve. Has this VI example been written? If so I would appreciate the oppoturnity to see the code.
Mike
michael.maher@noaa.gov
