Record& playback option in LabVIEW
Dear All,
I am trying to develop a Macro Recorder using labVIEW  in which i need to listdown(record) all the front panel event change(eg.control data change) and aftersome time using the list it must be played back.
I have put all front panel controls & indicators in a cluster(*where controls are the commond signa to the external hardware and indicators are the message resulting from the external hardware) and using controls property of cluster i detect the value change and label of the control and listing down in a array as variant since i have mixed data type.
Now when the user wants to play back, is there any standard method of doing this
kindly help me to resolve the same
chasan
(3,408 Views)
Hi chasan_2k,
you can use the value(sgl) property and write the value to it. It reacts as real click from the user.
Mike
(3,392 Views)
Are you using an Event Structure?
Tell us more about your code architecture so that we can offer suggestions that are easy to implement with your architecture.
R
(3,381 Views)
Thanks folks for the prompt reply
i m using event structure and value signalling to resolve it and almost working
will let you know if i require any help further
(3,372 Views)
