Recording analog input data to a file
I am performing a triggered Analog input acquisition (ACH0,ACH1,ACH2)based on a TTL trigger on PFI0 pin(using PCI 6052E DAQ board).How can I write the data to a file such that it can be easily read in Matlab or Excel. I tried using a '.bin' and '.xls' format in the file dialog when writing data to file but could not get any meaninful data when I tried to read it in Matlab or Excel.Can you suggest the file formats and the procedure to record the data being acquired from the three analog i/p channels ACH0,ACH1 and ACH2.
Shiv
(3,953 Views)
Shiv,
Refer to the example shipped with LabVIEW for I/O interfaces>>Analog Input>>dataloggers>> and Continuous Acquisition to spreadsheet file or binary file.
The spreadsheet file is a txt file that can be read by Excel or Matlab while you will need a binary file reader to read the .BIN file.
Cyril Bouton
Active LabVIEW Developper
(3,953 Views)
Hi Shiv,
Excel can only read ASCII text files, it usually can't read binary files of an arbitrary nature. You can convert your data into a text file during acquisition, so that the text file is created from the start, or you can convert your data as an entire file during post-processing.
To convert a binary number to a string, use "Convert Number to Decimal String.VI" This string can then be written to a file. If you de-limit the values with tabs, then excel should be able to read it quite easily. This conversion takes time, so you may want to do this during post-processing.
Another approach would be to port the data directly to Matlab or Excel using either the Matlab script node, or the Report Generation Toolkit for Microsoft Office.
(3,953 Views)
