Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
what is the difference between a port and a line
allred
Member
03-27-2002
07:09 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
and also difference between read or write to a port and read or write to a line
0
Kudos
Message
1
of 2
(3,332 Views)
Reply
Re: what is the difference between a port and a line
bman
Active Participant
03-28-2002
02:43 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
A port is a group of 8 lines. For E-Series DAQ devices, they all have 8 DIO lines (or one port). When using Write to Port, you are righting an 8-bit value to all 8 lines. If you use Write to Line, you are only writing a 1 or 0 to one line only.
Brian
0
Kudos
Message
2
of 2
(3,332 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
