Recording to measurement file at will
Hello.
I'm new to LabView and so far it's been quite easy to learn this software. I do really like i. I'm using a MCC USB-1208FS to measure signals from the real-world and sample them to LabVIEW.
The thing is that I want to be able to record to a measurement file at will. That is, when I press the start button it will start measuring but NOT saving data to measurement file untill I hit another button, a 'record button'. That's when I want it save data. Is that possible to implement in LabVIEW? Beause as soon as I start the sampling it saves to measurement file.
What functions should I use? I'd appreciate any help.
Thanks!
Message 1 of 8
(3,493 Views)
Accepted by Abraham_E
Quite simple with a case statement.
I would recomend :
3 hour course
6 hour course
Message 2 of 8
(3,477 Views)
Thanks. The case statement worked. I had to place the case structure inside the while loop in order for it to work.
Message 3 of 8
(3,456 Views)
bonjour,
je suis débutant dans Labview,j'ai besoin d'aide dans mon problème
Crées un fichier de configuration définira les caractéristiques du sujet passant le test sur ergocycle (Config-sujet) et comportera les informations sur le nom, prénom, sexe, âge, taille, poids, et un champ libre pour ajouter des commentaires.(sous Labview)
Merci
Message 4 of 8
(3,444 Views)
bonjour,
Merci
Message 5 of 8
(3,443 Views)
STOP hijacking unrelated threads.
Message 6 of 8
(3,434 Views)
bonjour,
je suis désolé mais comment faire pour soustraire le problème .
N'importe où j'ai mis le problème que j'ai.
Merci
Message 7 of 8
(3,413 Views)
No one will answer you if you keep ignoring the rules. Start NEW thread!
Message 8 of 8
(3,411 Views)
