Redefining an already-defined cluster
I am using a pre-defined VI which has a pre-defined input control cluster. However, some of the input parameters in the cluster are co-related and therefore, dependent on each other.
I want to be able to enter just the main parameter with which the others get automatically defined. How may I do this?
I have tried to define the parameters separately and bundle them to that cluster, but that is not being accepted.
Thank you
Dheeraj
Dheeraj Bharadwaj
IIT-Madras
(2,617 Views)
Accepted by topic author dheeraj2102
Hi Dheeraj,
This one way you can update the predefined cluster with a new data. And when you are bundling it back you should define the exact input cluster type to the bunndle by name function. See the attached example. Hope this helps you.
(2,613 Views)
