Reference to Class Member Functions
Have you tried setting the parallel option for the for loop and use dynamic dispatch instead of VI server to run the VIs?
Message 11 of 13
(1,143 Views)
If I'm understanding the situation correctly, I think a better way to do it would be to create a "wrapper VI" - a static dispatch VI in the base class that calls the dynamic dispatch VI you are wanting to call. Then run the static dispatch VI asynchronously as normal - no need to do anything special to run it.
Message 12 of 13
(1,138 Views)
Do as Ben suggested (put "DoSomething" from the parent class inside the loop); then make each "DoSomething" a wrapper that uses "Start Asynchronous Call" to start the code that does the work).
Message 13 of 13
(1,135 Views)
