Refnum Slide "Visible"
@pincpanter wrote:
Could you please post your code so we can get out of this?
The "Refnum Icon" lives on the block diagram, so how could we hide it? Only controls on the FP can be hidden/shown.
No, unfortunately the code is very restricted so I cannot post it on the Internet! 🙂  However I have fixed it.
I created another VI as follows:
So the inputs are a "Static VI Reference" to the parent VI.  The name of the control "slide" in this case, and whether it is visible or not.  This is called by the SubPanel VI before the call to the library VI and afterwards to make the progress bar visible and then invisible.
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
Message 11 of 16
(951 Views)
@NitzZ wrote:
Hi Christopher Povey,
Check the attached vis. Let me know if it helps.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved:smileywink:
Ah, I see.  I am reusing VI methods from past projects and the SubPanels were populated with:
I was not aware of this control, which would have made life easier! 🙂
Excellent, Thanks.
Christopher Povey
Message 12 of 16
(949 Views)
Nitz
Quick question.  How did you create this:
Christopher Povey
Message 13 of 16
(944 Views)
Nitz
Ok, got it! 🙂
Christopher Povey
Message 14 of 16
(939 Views)
Nitz
Actually this is no good for me.  When the SubVI runs it disappears into it and other subVIs, and the main panel are then locked out!
Christopher Povey
Message 15 of 16
(934 Views)
To create that I right clicked the reference terminal of the "Call By Reference Node" and created a constant. In the constant, I right clicked and selected "Select VI Server Class">>Browse>>SubVI.vi. Hope this helps..
Nitz
(Kudos are always Welcome;))
Message 16 of 16
(931 Views)
