Refrence file error in exe
Hey there.... thanks for Helping me so far..
I am stucked at a point again... I am making a application for report generation.
Using HTML report generation... But as I want to append my report to previous What i do is open that report as word type...
Now.. VI is working fine... but as I make an EXE it gives error about reference fie...(word_quit.vi)
" file <path> is not found or file not found" like that and path in that error only points to the location i buid exe.
I couldn't find the word_quit.vi anywhere.. and Main VI is working fine.... BUT as i build exe it won't work..
Can anybody help .. ?
(2,796 Views)
when you use report generation and then you create an executable, you've a problem. Some report generation vi's are not on the tree, so they are not build together with the rest of the program.
You have to find those missed vi's and add them in "add dinamically"
Software developer
www.mcm-electronics.com
PORTUGAL
(2,789 Views)
Hi Cyborg,
I believe this knowledgebase article addresses this issue. Let us know how it goes!
-Sam F, DAQ Marketing Manager
(2,764 Views)
