 dasari
			dasari
			02-17-2010 12:31 AM
 Guruthilak
			Guruthilak
			02-17-2010 01:21 AM
i did the same from 2009 to 8.5.1 and its fine...
may be a bug in 8.6 version?
02-17-2010 02:32 AM
thank u sir,
even i did with LAB VIEW 2009.No problem.it was fine
Problem is happening with 8.6.
 Guruthilak
			Guruthilak
			02-17-2010 02:44 AM
by the way why you just want to lock the vi? anyone (i guess) can unlock this vi by going to the vi properties or just by hitting "ctrl+m"
why dont you password protect the vi?
02-17-2010 02:54 AM
hi guru,
i can put password protection.and at the same time i am looking for the following application context:
In My application,i placed one multi column list box in front panel in which i can display all the run time data dynamically.
I want to make that mulicolumn list box cells(columns and rows) as Read-only.For that i am not finding the right option to make the same box read-only.
can u help me.
Thanks andregrads
Kavitha
 Guruthilak
			Guruthilak
			02-17-2010 04:50 AM
Make the multicolumn listbox as an indicator and your problem will get solved. i.e during run time the indicator can be used only for display purpose..
If still not solved attach your code
02-17-2010 05:13 AM
hi
after changing mulicolumn list box as an indicator also,i can edit the cells..
Not only in my applictation particularly,create mulicolumn list box( say 3x4) in front panel and try to make it as Read Only.
If u get any idea please come back to me..
thanks and regards in advance
kavitha
 Dennis_Knutson
			Dennis_Knutson
			02-17-2010 09:57 AM
02-17-2010 10:30 PM
dear sir,
Just check by creating one multicolumn having 3 or 4 rows and 3 or 4 columns and try to update that using array constant(for updating data into cells) as default for displaying values in box ..we can edit the cells in front panel not at running time and if u try to save vi it can be saved also.
Thanks and regards
Kavitha
 RavensFan
			RavensFan
			02-17-2010 10:35 PM
