Regarding Values in Controls and Indicators
antz007:
 please start a new thread since this is a new problem.  that way others can chip in as well.
- tbob
Inventor of the WORM Global
Message 11 of 15
(951 Views)
@mistercat wrote:
I am not at liberty to post my employer's proprietary code.
You can delete all irrelevant code and front panel objects and attach only the minimum that still shows the problem.
(Maybe all you need to leave is the control in question on a otherwise blank VI).
Could it be the "field" is actually an indicator and you have set "clear indicators when called" enabled under execution options?
Message 12 of 15
(946 Views)
If you right click on the control or indicatior an find all of the Local Variables, property nodes this will allow you to see where you might be interacting with this control or indicator.
Tim
GHSP
Message 13 of 15
(937 Views)
The problem turned out to be Front Panel Save-Restore.VI which I added at the beginning at end of my Flat Sequence Structure.  It was added after I had set some of the defaults but overwrote changes I tried to make later. It was tricky to find because it had nothing to do with the individual fields.
Message 14 of 15
(903 Views)
If it's fixed, why show it at all? Convert it to a constant. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 15
(882 Views)
