Regex to find spaces not preceded by a colon
Hi All,
With my limited understanding of regex, I am trying to find a space that is not preceded by a colon.  Trying "(?<!:)" on regex101 works:
but not when I use the Match Pattern VI.  Does that VI not work with a negative look behind?  Am I formatting it wrong?  Is there a better way to do my search?
Thanks!
John
(1,448 Views)
Accepted by topic author JohnEE
Match Pattern uses a limited set of regular expressions. Try using Match Regular Expression.vi instead.
Ben
(1,437 Views)
Plain ol' Match Pattern should suffice for something this simple.  I neglected to save and attach a VI, but this is pretty self-explanatory:
EDIT: since the primitive doesn't support capturing groups (the parenthesis syntax), the match substring output will include the non-colon character immediately preceding the space of interest.  I'll assume you're mostly interested in the offset past match numeric.
Hope this helps!
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(1,419 Views)
Thanks Dave and Ben,
I didn't realize that Match Pattern used a more limited version of regex.  I thought I only needed Match Regular Expression if I needed sub-matches, etc.  Since I was trying to break apart a string, using the space not preceded by a colon as the delimiter, Match Regular Expression in a loop seems the way to go.
Thanks again!
John
(1,339 Views)
