RegistrationWizard.exe has stopped working
I recently reinstalled LabVIEW 2011, and I am having a problem with the Registration Wizard. It keeps crashing at startup, either when the computer boots up, or when I manually start it in its program folder. I updated to SP1, but the problem is still there. Here are the details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: RegistrationWizard.exe
Application Version: 1.0.3.71
Application Timestamp: 4c1fd12d
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.23807
Fault Module Timestamp: 5915f98e
Exception Code: c06d007e
Exception Offset: 0000c54f
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
It appears it has something to do with KERNELBASE.dll, but I'm not sure what to do about it. Any help will be appreciated.
(6,261 Views)
Hey ilnus,
Was LabVIEW 2011 working normally prior to the reinstall? If so, have you tried reinstalling again?
(6,214 Views)
It was working, but recently I have been unable to compile code for FPGA targets. I did a repair of the FPGA module, but that didn't work. I decided to uninstall everything and reinstall from scratch. The FPGA compiler works now, but the Registration Wizard seems to be broken. I didn't want to reinstall again, since that will take a long time, and I already have the essential modules working. I just want to know if there is a way to repair/reinstall just the Registration Wizard, since it doesn't show up on the list of repairable software.
(6,211 Views)
Accepted by topic author ilnus
I found a workaround here on the forums. Let me know if this is an acceptable fix, or if it doesn't work for your computer.
https://forums.ni.com/t5/LabVIEW/Registration-Wizard-Running-at-100-CPU-After-LabVIEW/m-p/2254900#M7...
(6,196 Views)
That actually worked! I saw this post before, but didn't try the solution because I didn't have the 100% CPU issue, so I thought it was unrelated. Thank you BrandonC1!
(6,192 Views)
No problem, happy to help!
(6,188 Views)
