Why do I get Error -1967390704 when launching DSC?
After launching the Tag Engine, I get the following error message: "Error accessing historical database! Error Code -1967390704.
Help> Explain Error lists this as a possible reason:
"Socket has been disconnected by its peer".
My program has been successfully launching and using DSC for several months prior to this error. I tried cleaning the database folder to restart the database, but this did not help. I also renamed the "config.xms" file to force DSC to create a new one, but this did not help either.
Any suggestions, please???
(4,064 Views)
I was able to correct this problem by rebooting my PC. I'm still not sure of the cause. Any ideas?
(4,064 Views)
Most likely one of the NI Services (Logos ads, Logos time synchronization or Citadel) where not running anymore or where in a horrible stage thus just a reboot of the computer helped. And the LV DSC Engine as a data logger was disconnected from those services and gave this error.
I recommend to install the latest version of those services (Logos / Citadel) from:
Lookout Version 5.0 for Windows 2000/95/98/ME/NT/XP -- Citadel and Time Synchronization Servers
Hope this helps
Roland
(4,064 Views)
I just experienced exactly the same problem and solved with rebooting PC.
(3,040 Views)
