Regular expression help please. (extracting a string subset between two markers)
Thank you for your time! Really!
But please excuse my noobness! Again, I am experiencing some difficulties.
I do read the string nicely! But sometimes, maybe because of frequency issues, my communication board does not respond in propper time! Sometimes I do not read at all, or just manage to read partial information like "DAT " or "DATA 2" instead of "DATA 20.00", since the acquisition did not receive any information from the board in created attempts.
I am currently looping in order to verify if it read the full word or only partial. Is there any way I can control the number of decimal places after the point of the number on the string?
Or better, any way I can check if I have read all the string properly at once?
The string will always come with a word, a space and a number. Instead of your example to read from "!" to "?", may I or is somehow better to restrict it to the precise format? If so, what expression will match this string?
Thank you in advance!
Message 11 of 14
(1,932 Views)
@DMartins wrote:
[...] Is there any way I can control the number of decimal places after the point of the number on the string?
Sure.  If there will always be two digits past the decimal point the regex will contain \.\d\d or \.[\d]{2}
If you want to enforce the number of digits past the decimal point, change the last '*' to '{n}', where n equals the number of digits you need.  The regex will also need to change if there are some instances where there won't be a decimal point.  I may not have understood quite what you're asking.  Please provide some actual data, both correct and malformed, and we can figure this out.
Jim
Message 12 of 14
(1,914 Views)
Hello everybody ! I would like to post a question concerning the subject of this thread. How to get all the characters between 2 delimiters taking into account that the characters could anything from the ascii character list ? So for example the string could be :
 00 00 02 00 06 03 42 02
or
......B.
or
......à....Öh
or
..........€›Ò
or
How can i do this ? Andrew
Message 13 of 14
(1,853 Views)
Hi Andrei,
for example the string could be : 00 00 02 00 06 03 42 02
What are your marker values and what is the interesting part of the string?
A very simple approach (using 0x02 as marker byte) could be:
Message 14 of 14
(1,843 Views)
