Regular expression that detects all numbers (integer or float ) in any string ?
I don't believe it's possible to do what you want with a regex.  When you do a search for a regex, what gets returned is whatever portion of the input string matches the regex.  It will be an intact section of the input string; it will not be edited.  In other words, the search engine will not remove & discard pieces from the middle.
Message 11 of 16
(2,252 Views)
What are you really trying to do?
Why are the numbers coming in all mixed up with the other characters?
Message 12 of 16
(2,244 Views)
hi,
I try to extract just numbers from any String ?
example:
Qwerty12,45n67kiol89,
i want in the output : 12456789
Message 13 of 16
(2,216 Views)
But why are you getting a string that has letters in it?  Where is this string coming from?
Message 14 of 16
(2,208 Views)
Accepted by imadouino
It's easyer to remove everything that is not a digit. If you want to keep the comma add it to the character class.
Ben64
Message 15 of 16
(2,204 Views)
Thank youuuuuuuuuuuuuuu
Message 16 of 16
(2,175 Views)
