Reinitialize Arrays to Default Values
Hello everybody,
I am working with a progam that can perform two different tess in sequence. After that, the program saves the values into arrays to be saved in a spreadsheet. Sometimes though, I only need to perform one test. However, my program includes in the spreadsheet the values of the one test I choose not to run by taking the values from the previous run. Is there a way to reinitialize arrays to empty?
Thank you.
(5,122 Views)
It is difficult to say without having a good understanding of what your code currently does. A picture says a thousand words; please post what you have so that you can get better davice.
(5,120 Views)
Thank you. Here is the code. The arrays I would like to reinitialize are the ones called DC Test Values and Pulse Test Values.
(5,115 Views)
Accepted by christianwos
I didn't see the arrays you mentioned in the submitted code, but creating an empty array is simple -- put an Array constant on the block diagram and fill it with an element of the appropriate type.  For example, here is an empty array of Dbl:
Wire this wherever you need an Empty Array to appear.
BS
(5,097 Views)
The simple solution is just to write an empty array to all of your test results when you start a test sequence.  Maybe add another state for sequence initialization.
(5,094 Views)
Thank you.
(5,075 Views)
Thank you.
(5,074 Views)
