Reinitialize Default Value of Numeric control
Hi all ,
     Is it possible to reinitialize default value of numeric Control while running labview ?
(3,917 Views)
yes it is possible. One simple solution is attached - right click on the control and create an invoke node.
CsabaF
(3,900 Views)
HI CsabaF,
 I think my question is wrong ..
i need to update my default value ..
for example ..
 if my default vlaue is =  4
while running == i am decreasing to 3 then i need to update this value as my default value..
is this possible?
(3,892 Views)
I see - as far as I know it is not possible with vi methods, but this might be interesting for you
CsabaF
(3,888 Views)
hi CsabaF,
First of all
i wants say for your Kindly reply ...
Your second Post Seems okay for me but it in my case i have loots of input controls
i have added VI file as example (if i get some easy solution means no need to create config file process)
(3,880 Views)
A config file is an easy solution.
(3,873 Views)
here in my attached vi those inout controls are default inputs controls ..
i tought to update default value while running ..
Okay i go with Config file ,,,
thanks
(3,862 Views)
