Saving and Reading Spectrometer data
Hi there,
I'm using Labview 2012 and a USB2000+ Spectrometer (from Ocean Optics). At the present time I am able to comunicate LabView with the Spectrometer, configure it and even display the reading in a XY graph.But I also need to save the acquired data so I can open it again later in a XY graph, but I'm failing at this.
What is the best way to save/read this kind of data? (a 2 Dimensional array, I believe).
I tried using Write to Spreadsheet File and it even saves a file, but I cannot open it afterwards.
I will attach my program here so you can understand better what I tried to do.
Thanks in advance,
Liepo
PS: maybe to open the program you will need some VI's that are here :
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7833BD4A31DA1274E04400144FB7D2...
(3,411 Views)
(3,391 Views)
Could you answer me ?
(3,366 Views)
No.  That message is to direct people to a single post where they can answer you.  This way people won't waste time helping you in one message, when you are already getting help in the other.
(3,357 Views)
