Remote Administrator used to program in LabVIEW on a remote computer system.
I need to program on and administer a computer located on an island located off the coast of California.  Presently, I'm using LabVIEW for the programming and Remote Administrator (rAdmin) from Sunbelt for the connection.  Unfortunately, several features don't work within LabVIEW when logged on remotely, which seriously detracts from my abilty to do the job.
First, the right click button does not work.  This is a major flaw because it prevents me from being able to do any of those functions within LabVIEW which require that feature.  Second, drop-down controls don't work, which can also be a mojor impediment.  Lastly, the cursor does not change when manually changing tools (which I do ALL the time using the TAB key).  This one I can work around, the others I can't.
I was unhappy with the speed of Norton's pcAnywhere, which was why I switched to rAdmin.  I haven't taken the time to search for any other programsa whivh afford me the same functionality.
Thanks in advance for any feedback.
(2,740 Views)
Hi NJ,
      I'm confused (normal state, no need for concern) - is LabVIEW installed on the island, or where your fingers are?  (I'm assuming you aren't on the island.)
Hmmm?
When they give imbeciles handicap-parking, I won't have so far to walk!
(2,731 Views)
Thanks for responding.  LabVIEW resides on the island.  I'm accessing from my base here in California (China Lake).
thanks again....Jack
(2,711 Views)
