Remote Front Panel using the Web Server in an Application - Licensing issue?
I need to find out about the licensing issues regarding running 2 applications on 1 computer, and using the web server to remotely control them.
My 2 applications will be running in different directories, such as
C:\Program Files\app1
C:\Program Files\app2
As a result, I have created html outputs for both applications, and stored it under the webserver directories.  I have changed the app2 web server port to 81 in the app2.ini file.  However, still I don't get a response from app2 on port 81.
I read here (http://digital.ni.com/public.nsf/allkb/CD44B8A4DFDADAC386256BBB006F05F5) that there are licensing issues for this configuration.  How do I go about resolving these issues?  Who should I contact for an extra license to run this setup?
Regards
Slade
(2,895 Views)
Hi Slade,
I recommend that you check out the product page or consult your Internal Sales Representative here at National Instruments.
-Sam F, DAQ Marketing Manager
(2,879 Views)
