04-17-2007 09:58 AM
04-17-2007 01:28 PM
This is correct the bounds:left is the position to the origin of the front panel. This is not necessarly the upper left corner of your window. From your screen shot this is difinitly the case. You can use the scroll bars to wove the window in edit mode to have your window left and the Yorigin match then your numbers will work.
Paul
04-18-2007 03:33 AM - edited 04-18-2007 03:33 AM
메시지가 04-18-2007 03:34 AM에 labmaster에 의해 편집되었음
04-18-2007 12:10 PM - edited 04-18-2007 12:10 PM
Message Edited by Duffman Says: on 04-18-2007 12:12 PM
