Remote Labview problem
Hello!
I have a NI USB 6341 DAQ that suppose to control a PMT and LED trough Labview 2010.
But, Labview is not installed in my personal PC, I use it remotely from the University and I'm facing problem to use DAQmx (version 9.3.5) in Labview.
What I want to know is how to make my remote Labview to see the DAQ in my computer.
I imagine this is a very simple question, but after hours trying to find a solution I decided to ask the experts... 😉
Thanks!
Message 1 of 12
(5,369 Views)
Hello RadGent,
Is the USB 6341 connected to your University PC?
Or is it connected to your personal PC?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 12
(5,335 Views)
Hi
This is connected to my personal PC.
regards
Message 3 of 12
(5,330 Views)
Hello RadGent,
So your LabVIEW and DAQmx is installed on one pc (university) and your USB DAQ-device to the other one.
This is not the intended way to use a USB-device.
The PC that has the USB DAQ-device connected to it should have LabVIEW installed on it.
Is there a specific reason why you don't install LabVIEW on the personal pc?
Kind Regards,
Message 4 of 12
(5,325 Views)
Hi
I have DAQmx installed in my personal computer as well.It's only Labview that I need to acess remotely.
This is a service provided by the university where you have acess to many softwares without the need on stalling then on my personal PC.
I saw this https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x5DmCAI&l=en-US, but don't know if that would work in my case.
regards
Message 5 of 12
(5,321 Views)
Accepted by RadGent
Hello RadGent,
That solution won't work in your case.
However with NI-DAQmx 8.0 and later, NI-DAQmx OPC capabilities can be used to achieve reliable network functionality from remote systems.
RDA (as mentioned in the document you provided) is not supported in NI-DAQmx.
You could try something like this:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2CMCAY&l=en-US
The best and easiest steps to take would however be to install the software locally, especially because you're working with a USB-device.
Going over ethernet to the university and back to the same pc to connect to the DAQ board would seriously increase the latency of the system.
Kind Regards,
Message 6 of 12
(5,317 Views)
In the end I installed Labview on my computer and problem was solved.
Message 7 of 12
(5,293 Views)
I,
I have a problem in an implementation in labview.
I need to estabilishes a connection with internet, that means, when i need to go to my page created i can push the button and many things.
I follow this article.
http://redacacia.me/2010/10/15/internet-control-of-a-labview-vi-part-ii/
The problem is my IP because don't fixed? How fix my IP?
Message 8 of 12
(5,244 Views)
Hello fasp,
Your question doe not seem to be linked with the original question.
Can you please create a new forum post for your question?
Kind Regards,
Message 9 of 12
(5,213 Views)
Please, see this link in forum.
I need help in a project and if you can help me woulb bee fantastic.
http://forums.ni.com/t5/LabVIEW/Labview-Remote-conection-and-acquire-sound-and-image/m-p/2542605/hig...
Message 10 of 12
(5,191 Views)
