Remote Panel: how to load a vi into memory without showing it on the screen
I'm using the remote panel facility of LabView 6.1 to allow any user
to control my instruments from within a web browser. However, in order
for this to work, labview has to be running and the vi opened on the
server, which i want to avoid.
Is there a possibilily to enable the labview web server and load a vi
into memory in the background, whithout showing it on the screen?
thanks
(3,084 Views)
You could use a Win32 API call to hide the VI's window. It won't bother the web server, but it will get it off of your server's screen. I can't remember where to find the Win32 library online, but I've got one that I like to use. I can send it if you drop me an email.
There may be a more elegent way to do what you want, but the RFP functions are rather rigid about having the host VI's panel open.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
dan.press@primetest.com
(3,084 Views)
Not at the moment. The VI truly is running on the server and simply
displaying on the remote machine(s). At the moment it also needs to
have a display on the server. You probably could write a small VI to
periodically look for open LV windows that have connections to them and
minimize them. Then run that VI on the server.
Greg McKaskle
(3,084 Views)
goto www.ni.com and search for
windows api function
(3,084 Views)
